PTPv2.Critical
Description
A serious problem has been detected which is compromising the operation of the system. The system can not function as expected unless it is remedied. The problem may be related to hardware failure or software data corruption.
Remedy
The exact remedy is dependant on the particular situation; but the problem may not be resolved without intervention of some sort.
Severity
Critical
Message Text
%format%
Message Parameters
Name Type
format Printf
Applicable Platforms
